need help with O-ring choices
EvilNeo
i need to buy a mechanical keyboard from amazon and settled on the red dragon that was on linus' mechanical keyboards roundup video
https://www.amazon.com/dp/B016M91SS0?tag=viglink20940-20
it look good and within my budget but it's blue switches so the clucking noise might be a problem, so i'm looking for o-rings in amazon but there's lots of options
so what o-ring would you recommend? ,do you think they won't make any difference at all?
why not get an mx brown if you worry for noise?
O-rings only help with the clack when you bottom out at the bottom of the keystroke. They do nothing to dampen the actual clicking of the blue switch.
And blue switches are clicky.... really clicky, especially at night when everyone else is trying to sleep.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
couldn't find any good brown keyboard and be within my budget ,most of them are without a numpad which is kinda a deal breaker for me
I like blues but the orings dampen the bottoming out sound not the click which is the actuation point
