Hey guys I just built my first computer , it costed me $550 and I'd like to say it was worth it. I need some help though. I transfered my HDD from old computer into this new one and I'd like to setup a SSD. The only problem is I dont have a Windows Boot Disk. Is there any way i can get my OS on my SSD as a boot drive ? I really dont care if I lose my files (other than os). I want to do this to speed up my computer , and set it up for overclocking!
Just encase you were interested this is what I built
mobo : 970 Pro gaming Aura
psu : Masterwatt lite 500 80+ full range coolermaster
GPU: Geforce GTX 1060 OC edition
Ram : Ballistix sport gaming memory
Processor: AMD FX Processor (black edition)
Yes I know I could have gotten a better rig for $550, but this is what I got.
https://linustechtips.com/topic/814948-setting-up-new-ssd-need-help/
Do you have the windows activation key from the other computer? What version of Windows it it? If it’s 7, 8, or 10, then you can download a new image from Microsoft and either use thei tool to make a bootable usb installer or make an iso to burn to a disk.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
windows 10 or windows 7?
if windows 7, i think you need a new windows key..
windows 10, login to your microsoft account if you didn't, wait a bit and it should tie the product key with your account.
then, download the windows 10 64 bit ISO and then download rufus. get a 8gb or higher capacity USB that has nothing on it and plug it in. open rufus, drag the ISO (drag and drop) onto it. make sure it selected your USB and not an external HDD, and then click start
wait for it to finish, shut down pc
unplug HDD (to make sure it doesn't fuck up your existing windows install), then boot from usb
install onto ssd
plug back in hdd, boot from ssd, take all your files off of it and then format it using disk management
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
install onto ssd
I am upgrading to windows 10 right now. After I do that, then I can get product key?
you already have windows 10, or are you doing the free upgrade to windows 10 via 'microsoft im disabled please give me free windows'
or are you going from windows 7 to windows 10? you do need a new windows key (you can buy one from /r/microsoftsoftwareswap for $35 or so(
install onto ssd
Can I do this to get the product key? File Explorer > Right click "my pc" or w.e its called > Properties > Look for the product id?
im doing the disabled thingy
i don't know .. but a windows 7 product key won't work with a windows 10 installation
then i think you should get a windows product key from them, you can use that in the installation.
Alright. I found this video :
 is it still relevant ? its quite straight forward.
yeah it should work, i haven't done it that way but you can try it and see if it works for yourself (probably will, since the tool is from microsoft themselves)
please don't run the setup INSIDE windows. you need to boot from the USB to install it ..
So once i download that, what do I do? I need clear clear instructions (dumb version) I really dont want to lose my os nor my drives
What do you mean?
in the end of the video i think he ran the installer inside windows, can't really tell as my internet is being a piece of shit and youtube doesn't load properly.
you need to shut down your computer, then go into the BIOS, and then boot from the USB (change the boot priority from HDD to USB)
install onto ssd
you can download the windows 10 ISO using the windows 10 download tool on microsoft's website, but you need to save it as an ISO for 'burning to DVD'
Im going to do that method you told me with rufus. is it the best option for me?
I want do to this on a usb though not a disk. I dont know if my disk can burn cd's
Rufus is a utility that 'burns' ISOs onto a USB, ISOs can also be used to be burnt onto a DVD however.
It's like a ZIP, you can put the contents inside your downloads folder or another drive in another location (ISO is not a ZIP, its a bad analogy)
yup
yup
Dope, ill give that a try. This windows 10 upg is about to be finished though, so Ill wait for that and get my product ID. Is the product ID the same as the code you use to register windows?
no
since you said you are going to be using the disabled method, you are going to need to contact microsoft to do the thing, and then wait for them to give you a product key
product ID is NOT product code.
no
Oh so how will I get it then? Im confused xD
i am confused
how are you going to get a windows key?
product ID is NOT windows key
you do need one if you want to do some customizable things I guess, and to remove that 'activate windows' watermark on the bottom right of your screen
no
I found this: Is this what i do? http://prntscr.com/g27xyp
i am confused
http://prntscr.com/g27yn2
that means if you went from windows 7 / 8.1 to windows 10 when the free upgrade period was still a thing (i think sept 2015 to sept 2016) then you don't get a product key (one that is typable, like XHJUSHIUDH), but it is linked to your microsoft account (IF you are logged into one)
that is just more information..
