Hello everyone,
I have a rebuilt computer from IBUYPOWER and it has served me well for the past year. I have however found the stock cpu fan that it came with is LOUD. I am in the market to replace it but I want something small and compact.
https://linustechtips.com/topic/814911-cpu-fan/
1 minute ago, Kevinc said:
Hello everyone,
It would be helpful if you could provide us with more information:
  • What is your CPU/mobo (some coolers won't work with certain mobo cause there isn't a mounting brackets)
  • What case is it or if there is no name, what model of prebuilt is it (coolers come in different size so some may not fit)
  • How much you'd like to spend
https://linustechtips.com/topic/814911-cpu-fan/#findComment-10223000
We need system specs before we can recommend anything. personally I always recommend the NH-D15 but that isn't always the best option for some lol.
https://linustechtips.com/topic/814911-cpu-fan/#findComment-10223024
