Hi, I'm planning to rebuild my computer in a smaller, custom case, but I havr no idea which fan setup would provide the best airflow. Here's a quick drawing of the project (though I will probably use a riser and install the graphics card horizontally)
I have two 120mm fans from my cooler master masterbox 5. Should I
1 - put both of them at the front of the case (which will sit horizontally) and cut a passive exhaust vent at the back
2 - do the opposite (passive intake, two exhaust fans)
3 - put one at the front, the other at the back
4 - buy (or make) a pwm splitter and an extra fan so that I can install two intake fans on one header, and still have an exhaust fan at the back.
Thanks.
https://linustechtips.com/topic/814801-custom-case-airflow/
The only thing that matters is this
so long as the air thats in the case is going out and new air is coming in , that's all that matters. So long as the individual componenets (cpu , gpu , power supply ect...) are not reusing the hot air they make to cool themselves off , then they will be fine.
https://linustechtips.com/topic/814801-custom-case-airflow/#findComment-10221888
