Samsung Rapid Mode
Go to solution Solved by W-L,
1 minute ago, Saddy said:
Hello, I have seen a lot of things about samsung's rapid mode, and want to know if it is worth it. I have 16GB of ram and right now get GQRrOs5gTXSrc04ThAEyDQ.png
At idol I do use a lot of ram, 45%, as I use a lot of google tabs and programs. Would it be worth to use rapid mode? Also, does it effect life span? I want this drive to last for a long time.
It works as a caching system for the system so it's not a bad option, I have it enabled on all devices. Just note that it does potentially have some chance of increasing data loss if it was caching something critical and a power failure occurs, this however would be the same case if you had a HDD with SSD caching.
If this post solved your problem, please press the check below :).
https://linustechtips.com/topic/814675-samsung-rapid-mode/
i've been using rapid mode for 2 years with 32 GB of ram. Still going at it strong (850 EVO 500gb)
Current Build
Successful Builds
https://linustechtips.com/topic/814675-samsung-rapid-mode/#findComment-10220626
What performance do you get with it?
https://linustechtips.com/topic/814675-samsung-rapid-mode/#findComment-10220629
https://linustechtips.com/topic/814675-samsung-rapid-mode/#findComment-10220630
https://gyazo.com/1de7e4cecab24573c77602eecf5063c6
Current Build
Successful Builds
https://linustechtips.com/topic/814675-samsung-rapid-mode/#findComment-10220641
