Hello,
Okay so first let me start off by putting my specs.
Motherboard :Z97X Fatality (latest BIOS)
CPU: 4790k  Stock clocks atm
Ram  : G Skill 32 GB 1866 Trident X
GPU :  SLI   1080ti FTW3
I had a H220X that was having pump issues. and was just outside of warranty.  The best solution in my mind was to replace it with the H240x2  fair enough.  So I followed the diagram wired it up as the instructions said and the AIO is functioning well HOWEVER not a single light to be found any suggestions?   Thanks in Advance.
https://linustechtips.com/topic/814618-h240x2-no-lights/
