Just now, DamianR19 said:
Hey its me again I need some help figuring out what mobo to get. I have a i5-4460 and want a board that can support upto 16gb ram and a 1tb hdd + 120gb kingston ssd.
How many sata slots do i need? Also what is pci express? Do i need that
https://linustechtips.com/topic/814311-novice-need-help/#findComment-10216846
PCI Express is for your graphics card. So unless you want to use onboard you'll need PCI express, I don't think you can actually get a board without it but I could be mistaken.
You'll need a Z87 or Z97 board socket 1150.
https://linustechtips.com/topic/814311-novice-need-help/#findComment-10216884
Got a link? Im very shit with computers
https://linustechtips.com/topic/814311-novice-need-help/#findComment-10216885
OK, a few things.  PCIE is what your GPU uses to plug in so you need it.  You need 2 SATA (one per drive)
Just about any mobo with these chipsets will work
Intel® Z97 ChipsetLaunched2.03.0/2.0
Intel® H97 ChipsetLaunched2.03.0/2.0
Intel® Z87 ChipsetLaunched2.03.0/2.0
Intel® H87 ChipsetLaunched2.03.0/2.0
Intel® H81 ChipsetLaunched2.03.0/2.0
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/814311-novice-need-help/#findComment-10216894
