I'm not sure if this is supposed to go here, but I'm putting it here. I recently built my PC inside of a P400S TG. The included light strip worked and my PSU was faulty. It stopped working after a week so I replaced it. So I just finished wiring t up and the computer runs fine, but I noticed my RGB strip wasnt working. Nor was the light up power button and lighting on the bottom of the case. I did what the instructions said. The instruction were on the wire itself and still it didn't work. After trying other things like plugging the lights into different sockets, it still didn't work. HELP PLEASE. TIA
https://linustechtips.com/topic/814072-phanteks-rgb-lighting-issues/
Could the faulty PSU have fried it?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
2 minutes ago, IAR117 said:
it was working before. Also, the psu worked but it turned on and off by itself so it couldn't have as it still worked
The RGB strip is connected to the case lighting header, and that is connected to a SATA power cable?
Mouse: EVGA X17
Ok then, I'm in front of my PC and all the RGB strip is connected to is this-
I can't remember plugging it into any other power cables. Which one is the SATA power cable? The only SATA power cable that comes to mind is the one powering my SSD. Does it connect to my motherboard? There is a short 4 pin female connector at the end of the RGB strip.
Edited by IAR117
That is how you connect RGB strips together. If you trace that back to where it came from, you should find the controller. It's powered by SATA, just like your SSD. Plug it into your PSU and it should work. On my Evolv, the SATA connector was just dangling in the back of the case.
Mouse: EVGA X17
