VESA Mountable Ultrawide monitor
Billy_Mays
I want to get a new display since my current one is 900p and it's only 19.5" and I don't like the format I've seen 16:9 monitors and they are nice and I probably will need decent colour reproduction because I would need to photoshop some thumbnails for my videos and I also want them to have speakers I know most will go why but I'm going to be making a custom desk and the VESA mounting will come in handy for when I want to do videos for a build or scripted video and it doesn't matter to what resolution only if it's an Ultrawide under $500 snow pesos
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
LG has a decent amount of "budget" ultrawides. I'd check them out on PCPP.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
im very confused
i would put some of that money towards upgrading your build, but you could probably find an aftermarket adapter to VESA for any ultrawide monitor if you really want it.
