How many NZXT Aer Fans can I connect to the NZXT Hue+
12 minutes ago, GlowingTurtle54 said:
I wondering if I need to hook up all of the fans to the motherboard or to the NZXT Hue+
dunno but why dont you get a splitter? Theoretically a single PWM header could power 4 fans
Hey, this fan splitter has a lot of good ratings, I'd recommend you check this out https://www.amazon.co.uk/Akasa-AK-CBFA04-15-Splitter-Cable-Fans/dp/B005FWXWPS and as Tiwaz said
On 7/28/2017 at 6:58 PM, Tiwaz said:
just look on amazon
