Adults Help
Solved by thrilledtear,
Just now, valdyrgramr said:Again, not sure how Canada does it. You might have sites like Zillow that would break it down for you. Look for legit real estate sites for Canada. Or, call a local realtor?
for any canadians running into a similar issue...... use https://www.realtor.ca/ ♥♥
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases3 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
