extreme mouse stutter
Go to solution Solved by Spork829,
A hair got into the opening for my mouse's sensor and caused something similar a while ago. So check that and maybe take some canned air to the sensor area. Otherwise I'm not sure.
My beloved NAOS 7000 has been stuttering a lot lately and I don't know why. I thought it was my mouse pad, but it only happens intermittently. Then I though my DPI was too low (450), but I used to run it at stuff as low as 400 no issue. Why is this happening?
M1 MacBook Air 256/8 | iPhone 13 pro
https://linustechtips.com/topic/813170-extreme-mouse-stutter/
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/813170-extreme-mouse-stutter/#findComment-10204232
I did have to take it apart to get some water out, but this only started a few days ago.
https://linustechtips.com/topic/813170-extreme-mouse-stutter/#findComment-10204237
i think you may have been right...
https://linustechtips.com/topic/813170-extreme-mouse-stutter/#findComment-10204239
7 minutes ago, RGProductions said:
there was a piece of hair on there, blew it out, and it seems to work now! LOL! if only I had done it earlier I coulda had that ace
Glad I could help!
https://linustechtips.com/topic/813170-extreme-mouse-stutter/#findComment-10204297
