https://uk.pcpartpicker.com/list/XKLTcc
Should I stick with the zotac or get the evga ftw 2 for £475?
CPU: Ryzen 3700X Motherboard: Gigabyte X570 Pro Wifi CPU Cooler: NZXT Kraken x62 Rev 2 RAM: 16GB Corsair Vengeance DDR4 3000Mhz GPU: Asus TUF OC RTX 3080 SSD: 250GB SK Hynix SATA and 2x 1TB Samsung 980 Pro M.2 PSU: Corsair SF750 Case: Cooler Master NR200 Monitor: LG 27GL850 Keyboard: Logitech G810 Orion Spectrum Mouse: Razer Viper Audio: Sennheiser PC37X and Logitech G560 Speakers
https://linustechtips.com/topic/813137-how-does-my-build-look/
Build looks good, very happy with my 1070 AMP Extreme so I dont see why you would pay more for the EVGA (If anything the cooler is less beefy on that).
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/813137-how-does-my-build-look/#findComment-10203765
Thanks my man, I couldn't decide which to pick I needed someone to do it for me lol
https://linustechtips.com/topic/813137-how-does-my-build-look/#findComment-10203769
Like @rn8686 said, the AMP! Extreme is a beats if a card. So is EVGA’s FTW series (I prefer EVGA), but I’d go with whichever matches your build best. You won’t be disappointed with either, that’s for sure.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/813137-how-does-my-build-look/#findComment-10203840
Yeah they seem like very similar cards only thing that sticks out with the FTW2 is the rgb but if it means paying an extra £20 then I will pass
Edit: I think the zotac has rgb however the rgb on the FTW2 is on the side which is the part visible from Inside the case, no idea why companies put rgb around the fans because you will never see them.
https://linustechtips.com/topic/813137-how-does-my-build-look/#findComment-10203869
If you like EVGA, just go with the regular FTW card.  The difference between FTW and FTW2 is minor at best, and cards shipped out now have the updated BIOS and thermal issues fixed.
Midnight Rig - CPU: i7-7700K / Cooler: Corsair h100i V2 / Motherboard: AsRock Z270 Taichi / RAM: G.Skill TridentZ 3200Mhz / GPU: EVGA GTX 1070 FTW2 / SSD: Crucial MX300 525GB / HDD: Seagate Barracuda 2TB 7200rpm / PSU: EVGA Supernova B2 750W
https://linustechtips.com/topic/813137-how-does-my-build-look/#findComment-10204155
It wasn't thermal issues, it was faulty VRM components ;)
MOSFETs are designed to run with no problem at 120°, so it was well within spec
https://linustechtips.com/topic/813137-how-does-my-build-look/#findComment-10204167
At least those issues are resolved now, so any new regular FTW cards should be just as good.
https://linustechtips.com/topic/813137-how-does-my-build-look/#findComment-10204233
