I've got a Latitude E5570 with a sketchy wireless card that needs to go. I fished out a Vostro 3558 and salvaged it's wireless for the Latitude. The card is installed correctly. However, when I try to install the drivers, the installation fails with the message
"Installation Blocked"
"This software package cannot be installed on your system"
I'm positive I have the correct drivers but they still refuse to install. Any help would be appreciated
https://linustechtips.com/topic/812386-wi-fi-replacement-issues/
do you need the driver for the card to work? on windows 10 for me, ive tried about 4 wireless cards and they all work without installing any drivers (windows automatically installs them for you)
right click and try to install as administrator
what windows version and what wifi card?
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
Windows 7. I looked up the hardware ID of the card and its an Intel Dual-Band Wireless-AC 3160
Tried that...
Yes. Win 7 does not have basic drivers that work with this card
