Screen Resolution Problem
 Hey guys can you help me to fix this issue i got right now. Earlier my tv monitor works fine with native resolution and i can choose between 1920x1200 or 1920x1080 resolution anytime i want. but after i updated my gpu driver to the latest version that nvidia released my screen resolution force me to used 1366x768 with the highest setting of 1600x1200 resolution it hurts my eyes cuz the screen is to large and the icons too. I got 24 inch TV Led Monitor. so anyone knows how to fix this? Also i tried to uninstall the drivers and rollback to its previous version but it doesnt work now pls help thanks.
BTW i got this specs
Intel i5 4670k
GTX 650 TI Boost
24 inch led tv monitor
msi z77 g45 gaming motherboard
8gb of hyperx kingston ram
https://linustechtips.com/topic/81219-screen-resolution-problem/
Have you tried changing the resolution in both the display section of the Windows control panel and the Nvidia control panel? Sometimes that helps me.
yes i did try that too still it limits me to used 1600x1200. . before i updated my driver i used 1920x1200 resolution after the update it wont allow me to used it anymore im a having hard time to fix this thing  :(
https://linustechtips.com/topic/81219-screen-resolution-problem/#findComment-1112864
