just just a small pc together with old parts i had laying around my house for my living room but it has one problem, I CANT PLAY ANY GAMES. it boots up and everything works but the apu doesn't seem to be using its 6 cores for graphics. ik its a bad apu but it has a hard time with The Escapist and cant run this war of mine. its a a8 7600 amd anyone have any ideas?
https://linustechtips.com/topic/811536-apu-help/
full system specs help. ie single channel/stick of ram bottlenecks igpu performance, dual channel doesn't, and then there's the amount of ram, and how much turnip you use
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/811536-apu-help/#findComment-10185769
well, once you run updates if performance doesn't improve check ram and cpu usage while gaming
desktop
HTPC
https://linustechtips.com/topic/811536-apu-help/#findComment-10185787
