so am getting a lian li dk q2x desk case (hope u know what i mean) and well i want to make sure it looks nice and i need a storage upgrade i have a 500gb hdd atm and i was thinking of buying 4 250gb 850 evo's putting them in raid and being off to the races if u will. but i have questions as i have never done raid before.
first i dont need max performance this pc is only used for gaming so i just want the drives to run as if they was just a single 1tb ssd so what raid config should i go with.
second with the above raid config is there a limit on how many drives can be used in a raid for the config i would use if so i would just have two raids or 1 raid and a single drive for OS for example.
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/810402-raid-help/
with 4 ssd's DO NOT USE RAID 0, you will lose all your data if there us an issue with any of the drives. you cauld use raid 5 for a 750GB array with 1 drive redundancy but if your just gaming get a single 1tb ssd
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
https://linustechtips.com/topic/810402-raid-help/#findComment-10173703
with the lian li desk case i wanted to get get 4 drives purely for looks to make the case look full. so what your saying is use raid 5 on 3 drives and the other drive with say my OS and pictures on so if the raid dies am all good
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173722
no use all 4 drives in raid 5
PSU tier list-
https://linustechtips.com/topic/810402-raid-help/#findComment-10173730
ok
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173731
1 minute ago, myspeakersaremuffled said:
I'd recommend you scratch that idea and get a 2tb firecuda for 90 bucks on amazon.
y would i want to do that can i ask
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173734
or just 2 ssd's and a pair of hard drives for mass storage
PSU tier list-
https://linustechtips.com/topic/810402-raid-help/#findComment-10173735
Does your motherboard support JBOD in the raid options?  If not, you have to run raid 0.
I would advise you to run a single 1TB SSD than 4 smaller drives.  You're 4x-ing your chance of failure.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/810402-raid-help/#findComment-10173738
so that if a drive fails in the raid you don't lose any data
PSU tier list-
https://linustechtips.com/topic/810402-raid-help/#findComment-10173740
i dont need massive storage and the case can hold like 8 drives so u know
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173744
Because its a really good drive and will be fine for regular gaming, I have that one my self. It's a hybrid of an HDD and an SSD and is pretty fast actually. 5* as fast as other 7200rpm drives.
https://linustechtips.com/topic/810402-raid-help/#findComment-10173748
i know so is there a way i can have a failure and not end up fucked
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173750
JBOD basically glues the drives together and treats them as one large one.  Just a Bunch Of Disks.  If one drive fails you only lose the data on that drive not the entire thing (as you do with raid 0).
Raid also can fuck you over when it comes to managing your partitions.  Sooooo many boot CDs don't properly support Intel raid arrays and see the drives individually.  It's one of the reasons I'm consolidating my 4 SSDs down to 1.
https://linustechtips.com/topic/810402-raid-help/#findComment-10173761
then raid 5 4 drives or just spray paint old laptop hdd's to fill the blank spacesxD
with raid 5 yes, with raid 0 no
PSU tier list-
https://linustechtips.com/topic/810402-raid-help/#findComment-10173765
u lot know way more about this then i do but the case have 4 drive bays that i want to full 3.5 or 2.5" drives and i want them all to be the same drive as they will be on full display i just wanted to know if i could set up my drives so there all 1 drive but if anything shits the bed my data will be fine?
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173776
raid 5 or raid 1.
or as said above just mock up some fake SSDs to fill the case and only run 1 :)
https://linustechtips.com/topic/810402-raid-help/#findComment-10173781
with 4 hd bays i would maybe go for 4 1tb hdd's in raid 5 then and have an m.2 boot drive
PSU tier list-
https://linustechtips.com/topic/810402-raid-help/#findComment-10173785
raid 5
https://linustechtips.com/topic/810402-raid-help/#findComment-10173790
on that point buy a 1tb 850 evo and get samsung to sell me a bunch of ssd cases :D
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173791
or make them yourself
PSU tier list-
https://linustechtips.com/topic/810402-raid-help/#findComment-10173794
good point
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173795
that sounds like effort
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/810402-raid-help/#findComment-10173799
haha just get some old laptop hdd's and spray them silver, or whatever colour the ssd is
PSU tier list-
https://linustechtips.com/topic/810402-raid-help/#findComment-10173805
