I bought a new 2TB external HDD which I want to put everything on. However, my fairly new Flash drive (about 2-3 months old) stops being recognized whenever I do anything. I have tried 2 different command prompts, compressing the files and emailing them, coping it to the computer itself, and error checking. I have all my work from the last few months on this drive. Help is appreciated.
https://linustechtips.com/topic/810328-usb-problem/
1 minute ago, KenjiUmino said:
does the flash drive work without the hdd connected ?
I acts the same regardless. It is recognized at 1st and can see all the files on it but any time I try and access the files, move them or do anything it becomes unrecognized. It has stated a volume prb and I think something else
https://linustechtips.com/topic/810328-usb-problem/#findComment-10173050
try opening your flash drive in linux. If it does the same thing, then the connector or the memory ilself is damaged.
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/810328-usb-problem/#findComment-10173079
