I am running a nice system with a GTX 980 and everything worked fine, I have 2 screens - one is an old 4:3 monitor, and the other is a G2460P by AOC, a 144hz 1080p.
I was running my 4:3 monitor with a DVI cable (since it dont have HDMI) and my AOC with a DP (for 144hz)
last week my AOC monitor started stuttering until it just wont turn on anymore, so I got a new one (more like QA tested used one) under my warranty, but now when I plug in my DP, the only resolutions available to me are 1280x960 or 640x480.
I plugged it in every single DP connection on my GTX980 and all gave the same results, however plugging in a HDMI works fine but it only runs 60hz like that, and since I only have 1 DVI output on my GPU, I cant run both screens on like that (and I dont have a VGA on my MB or card, so thats gone too)
could that be a problem with the screen? seems weird to get another failed one that had a QA assurance sticker on it.. and Im afraid that my GPU might be dying?
https://linustechtips.com/topic/809811-problem-is-dp-only/
Sounds like a bad generic display port cable. Try buying a new display port cable :)
Current Build
Successful Builds
https://linustechtips.com/topic/809811-problem-is-dp-only/#findComment-10167295
Try forcing the resolution/ refresh rate using a custom resolution.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/809811-problem-is-dp-only/#findComment-10168344
A lot of problems with improper detection of resolutions can be solved by forcing the monitor to reset, so it will go through the handshake procedure again. Which basically means, try unplugging the monitor from power for a minute.
https://linustechtips.com/topic/809811-problem-is-dp-only/#findComment-10168359
