Hi guys,
I wanted to know if you had some ideas about the passmark baseline a cpu need to handle a 1080p/30fps (3k5 to 5k bitrate) stream ? And what about 2 streams on the same build ? Like on a Ryzen 1700.
Allways about this CPU, can he transcode via Plex a 4k movie with a good quality ? Not perfect but still good ?
Thx in advance,
Jérémy (a frenchie).
https://linustechtips.com/topic/809699-plex-and-obs/
  • 3 weeks later...
if his streaming 1x4k movie at a time. It should work however the cpu will run at about 80% the whole time. This depends what your streaming to. If he is streaming to another pc shouldnt get that high. however if he is steaming to a tv / ps4 or something like that. Then 80% it is.
https://linustechtips.com/topic/809699-plex-and-obs/#findComment-10291657
