Switching boot disks - will it work?
Solved by Alterlai,
You can swap boot drivers fine, but if you have another drive with programms on it that were installed with the first drive operating, the programs wont work on the second drive since there are no registry keys or signs that those programs were installed anywhere on the second OS.
You can swap them back and forth fine if it's just one drive in your system.
Featured Topics
Imapancake22 ·
Posted in CPUs, Motherboards, and Memory1 -
YFearless ·
PowerPCFan ·
1
6
2
2
2
