I recently build a new gaming pc with a ryzen 5 1600 and a gtx 1060 6gb, and i've been having this problem since day 1. Battlefield 1 is the most demanding game i have and i notice my gpu is not been 100% used.
Every time gpu usage drops, fps does too. I already tried most of the forum "tips" (windows energy modes, nvidia maximum performance options, M/B last bios update, nvidia last drivers 384.76) and nothing seems to help. I know the CPU should not be a bottleneck because all the reviews and youtube videos i've seen with the same specs dont have this issue.
I know there are like 100 post already with similar topic "1060 gtx gpu usage", but most of them were bottleneck problems or nvidia - windows power saving related problems, which i think are no the case here.
Here is a video where you can see what i mean:
My specs:
- Ryzen 1600 3.6ghz (OC)
- MSI B350m Gaming Pro
- Kingston Hyperx DDR4 2400mhz 1x8gb
- EVGA 750w BQ
- MSI GTX 1060 X 6gb
- HDD Toshiba 2Tb
- HDD Samsung 320Gb
I would really appreciate some help guys, this is driving me crazy.
https://linustechtips.com/topic/809685-ryzen-1600-gtx-1060-gpu-usage-problem/
Can you turn on K boost? it's supposed to make it run at the max boost speed constantly, so it won't keep fluctuating.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
My specs:
- EVGA 750w BQ
- HDD Toshiba 2Tb
- HDD Samsung 320Gb
Turn off your overclock
Turn on any setting that prevents the GPU from changing its speed, and manually set it to te max.
Check if you still have the problem. If you don't, renable the OC to check if that was the issue.
Check what clock speed you are actually running at. Aside from drivers, which I'm sure you've tried, all I can think of is you have the bug where OC'ing pins you at 1.5GHz which is why you can't utilise the GPU fully. Check this speed with a program like HWinfo64 or eliminate the possibility by going back to stock (for now) and testing again.
The quickest way to return to stock is to select something like "load optimised defaults" in the BIOS
I think I know what your problem is, you only have 1 stick of ram!
Most machines have multiple memory channels (ryzen included). They will run with a single stick, but you won't get the bandwidth of both or all of your memory channels. So it could be that your cpu is memory starved. Grab a second identical 8gb stick if you can and install that.
I already use "Force constant voltage" with MSI afterburner and no changes. The GPU keeps droping usage (and fps)
Like @101m4n said, you may need more RAM (I'd get at least 3000MHZ, RAM speed is just as important as clock speed on Ryzen). And what res/settings are you playing at?
Mouse: EVGA X17
That may be true, but it's always best to keep the ram on each channel matched. If he wants faster memory, he'll have to buy two new sticks rather than just one. A quick search on google though does confirm what you say, that ryzen does like higher memory bandwidth. So he is definitely not doing himself any favours by only running one stick.
Yup, so either a new 8GB stick of 2400MHz RAM (preferably the same type), or 2x8GB of 3000+MHz RAM (preferably on the mobo QVL list).
Mouse: EVGA X17
I'm using default ultrasettings on a 1080p 60hz AOC monitor. Not using dual channel technology, does it really impact performance that much?
About the 3000mhz ram, i got 2400mhz because the mobo did no support 2666 - 3200 mhz without OC (wich i really dont know much about). But i saw many ryzen 5 1600 reviews using diferent ram speeds and it basically improve a few FPS (2-5 at most), without any imporant performance impact.
In case i would go for 3000mhz, would i have booting issues?
Shouldn't. Though MSI mobs are known to have Ryzen problems (especially with RAM). Are you on the latest BIOS update?
And as for RAM OC performance, @stealth80 has proven it's way faster.
Mouse: EVGA X17
Yes i'm already with latest bios update, so if i install a 3000mhz stick i should not have any issue with BIOS BOOT?. Sorry about my english.
Nope. RAM runs at stock speed (1366 or something 2133MHz for DDR4) until you overclock it or select a faster XMP profile.
Mouse: EVGA X17
47 minutes ago, Zando Bob said:
Nope. RAM runs at stock speed (1366 or something for DDR4) until you overclock it or select a faster XMP profile.
The official JEDEC standard for ddr4 specifies that dimms run up to 2133mhz iirc, all sticks sold for higher speeds (2400+) will run at this speed without issue. When you see sticks being sold at higher frequencies, those frequencies are actually overclocks (even 2400), but they are actually pretty easy to use. They usually use something called "XMP" or extreme memory profile. These are overclock profiles which are actually stored on the RAM stick, all you have to do as a system builder is go into the bios and select the profile (speed) you want to try and use, you don't actually have to do any of the work yourself :). But every stick will be able to run at the base frequency specified by the JEDEC standards, so there's practically no chance that any sticks just straight up won't work.
As for the single stick thing, with two sticks, the CPU will spread it's usage across both sticks, effectively doubling your memory bandwidth. With only 1 stick it can't do that, for obvious reasons :P. One way to deal with your memory bandwidth problem is probably to go online and pick up another identical stick to the one you already have (which imho is probably the most cost effective/sensible way). Alternatively, as zando suggests, you can grab a new set of 2x8gb sticks that run at a higher frequency and use those, then return your current stick to get some money back. This would be more expensive, and higher effort, but would yield slightly better results, as you would get the extra channel worth of bandwidth + a bit more from the higher frequency.
It's also worth noting that ryzen has had some memory speed related issues, so look online for other people with your motherboard/cpu and check that they aren't having trouble with high speed memories if you do plan to go with faster dimms.
Aaah... it was 2133. I was sure it had a 3 in it...
Mouse: EVGA X17
Ok i will get another stick (i have yet to decide wich speed) and i hope it will resolve the problem. Thanks guys for your help, i'll be posting the results tomorrow to let you know what happens.
Good luck! :)
Take care though that the two sticks you put in the machine have the same speed/timings!
Yup, I saw my FPS in the RotTR Benchmark go from 87 to 101 FPS purely by going from 2133mhz to 3200mhz and keep in mind that is at 1440P, the jump at 1080P would be and was a lot bigger
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Problem solve by getting another 8gb 2400mhz ram stick. Before: 1x8gb 2400mhz. Now: 2x8gb 2400mhz. Dual-Channel and not the amount of ram did the trick.
ALWAYS USE DUAL CHANNEL FOR GAMING. Thank again guys.
Problem Solve:
  • 1 year later...
