Asus laptop problems
3 minutes ago, Idkwhat2putheresowhatever said:Its a 2.5" drive. The SATA configuration is set to Intel RST Premium and has a write speed of 427MB/s and read speed of 488MB/s.
then it seems your drives are working.. program loading times are dependent on the programs themselves... some will not load any faster even if you put it on a +6gb/s read speed nvme raid array.. (i know, i've tried)
as for the login issue.. i'm assuming you're running windows 10.. the easiest fix might just be to try doing a reset (remember to backup first) it should clear up any windows related issues and basically act as a clean install. alternatively, you can download microsoft media creator and install a totally clean windows 10 without any bloatware, it might even fix some issues with loading times if there are some bloatware hidden away hogging resources or something
also if it's brand new, it might just be running anti malware and indexing etc which can hog alot of resources, but this doesn't happen more than once per install in my experience
