Just now, BangBwoxz said:
Should I change to aftermarket cooler?
modding an outdated card that you intend to keep on using is not recommended
Desktop benching:
no,just make a custom fan curve
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
-ignore this-
Edited by McHox
4 hours ago, BangBwoxz said:
I've downloaded MSI afterburner, and set fan auto.. When idle its reach 48-49°C..
But when I use to render video file in Magix Video Pro its reach 70°.. Normal?
I would recommend making your own curve. I have a msi gtx 770 and the stock curve is just a flat 39% fan speed Which is stupid...
Play around with it and put the fan speed as high as you are comfortable with sound wise at 70-75 degrees c.
Sounds a bit high for idle but but good load temp if that is at 100% load.
