CPU Fan Error?!?!
Go to solution Solved by Billy_Mays,
Its the opt fan running
Just now, Aspirix said:
What does that mean
Google how to mkae the OPT fan the primary fan or plug it the other header
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/809215-cpu-fan-error/#findComment-10161056
2 minutes ago, Aspirix said:
What does that mean
Your CPU fan is plugged into the wrong header, switch it or make it the primary like @Billy_Mays said.
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
https://linustechtips.com/topic/809215-cpu-fan-error/#findComment-10161062
But how do i change it Then? :)
The easiest way to fix this problem is to simply unplug the CPU fan cord from the motherboard, and plug it into the port on the motherboard labeled CPU Fan. Not the optional one.
https://linustechtips.com/topic/809215-cpu-fan-error/#findComment-10161089
CHA Fan 1?
Nope, that would be Chassis Fan 1. What is your motherboard? Might make it easier to show where it is
https://linustechtips.com/topic/809215-cpu-fan-error/#findComment-10161114
I have attached a picture of your mother board with the CPU headers circled in red, the WHITE ONE ON TOP is the header it needs to be in, the black one on the bottom is where it should be currently located.
https://linustechtips.com/topic/809215-cpu-fan-error/#findComment-10161155
That worked thanks :) But so you know by my computer turns on and off 2-10 times before starting? This time it sayed overclock failed ? I havent overclocked?
https://linustechtips.com/topic/809215-cpu-fan-error/#findComment-10161182
Something like that is a little harder to troubleshoot via a forum, the first thing I'd try is reseting the BIOS(easiest way to do this is to remove the CMOS battery for like 30 seconds while the machine is unplugged and drained(unplug and press the power button over and over) then put it back in. You may have to reset time and date settings after doing this.
https://linustechtips.com/topic/809215-cpu-fan-error/#findComment-10161208
