Help for bc part
Go to solution Solved by Sultan179,
4 minutes ago, Septimus said:
Just put together this part list for you to give you a general guide, feel free to change up things like the motherboard and RAM if you want them to look a specific way, although I would still recomend 3000MHz RAM and a B350 motherboard. https://pcpartpicker.com/list/XyP2Cy
Thanks septimus helped me alot
Posted 18 hours ago · OP
Hi guys
iwant to bulid a pc fo rendering and
3d modeling  and phto editing
im an architect
iwill list the parts that i chose
just tell if ican do something bout it
thinks
cpu:i7 7700k
mb:GIGABYTE AORUS GA-Z270X-Gaming K7 Gaming
vga: ASUS ROG-STRIX-GTX1080-O8G-11GBPS ROG Strix
ram:16gb ddr4  3000mgz                    Corsair Vengeance
Cpu coler : crosair h105
storge:
1:nvme m.2 samsung evo 500gb
2:sandisc ssd 250gb
3:wd 1tb blue
ps:850w
https://linustechtips.com/topic/808625-help-for-bc-part/
What is your total budget? Also, welcome to the forums! :D
https://linustechtips.com/topic/808625-help-for-bc-part/#findComment-10154068
9 minutes ago, Sultan179 said:
cpu:i7 7700k
Get a Ryzen 7 1700 and a B350 motherboard to overclock it and potentially gain the same performance as an 1800X - it will treat you much, much better with video editing.
2:sandisc ssd 250gb
3:wd 1tb blue
ps:850w
For the NVME drive, I agree with your choice of a Samsung 960 Evo, that's a good drive.
The 1TB WD Blue on the other hand should be changed to a Seagate Barracuda 3TB HDD, it offers much better value and better performance.
The PSU should be around 650-700 watts to maximize the efficiency that you can get out of it.
https://linustechtips.com/topic/808625-help-for-bc-part/#findComment-10154090
Thanks my friend but if igo with amd
ist good for me to use it in 3d software and 3d rendering such as vray and iuse phto shop alot for matte pinting
thinks
https://linustechtips.com/topic/808625-help-for-bc-part/#findComment-10154251
thinks
Yes, the Ryzen 5 1700 would actually be much better for 3D rendering and Photoshop.
https://linustechtips.com/topic/808625-help-for-bc-part/#findComment-10154269
8 minutes ago, Sultan179 said:
What cpu coler should igo with
If you don't mind with going something mainstream, go with something like the Cooler Master Hyper 212 Evo
4 minutes ago, Sultan179 said:
And should igo with the x model from amd
No, go for the regular R7 1700. The only difference between the 1700 and the 1700X is clockspeed, which can be achieved through overclocking the CPU. This basically gets you the identical performance of a 1700X for less money, therefore increasing the value of the R7 1700.
https://linustechtips.com/topic/808625-help-for-bc-part/#findComment-10154326
https://linustechtips.com/topic/808625-help-for-bc-part/#findComment-10154358
https://linustechtips.com/topic/808625-help-for-bc-part/#findComment-10154383
