Depends on the game. Most 1080 games will use about 3-4GB.
I would strongly suggest going for the 6GB not for the VRAM, but the stronger core since the cores get killed way before VRAM becomes an issue.
Edit: If you don't have enough VRAM, you may need to employ higher speed storage to allow faster swapping between textures, etc.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
1060 is fine for that. do get the 6 GB variant because some games require 2 gb or more to run at high settings
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
Settings don't affect Vram that much.
Even Resolution doesn't affect it THAT much (it does abit. But it's not the most important thing).
What will limit you in 1080p, are Textures.
If you have 3gb Vram, instead of 6gb, you will probably still be able to play msot games in High - Ultra in 1080p @ 60 fps.
BUT: With 3gb Vram only, you might have to reduce Textures from Ultra/High to Medium or even Low depending on games.
This CAN impact your visual quality greatly.
TL;DR: You will have to make compromises in Texture quality. That's it.
What i personally can tell you, i had 1080p / 60 Hz untill a few months ago, and i had a GTX 1060 6gb (MSI Gaming X).
Rise of the Tomb Raider maxed out (also Textures very high) used up more than 5.5 gb Vram even shortly after loading a save. depending on Area of course.
Reducing textures to 2nd highest, dropped the Vram consumption down to like 3 - 3,5 gb~ (luckily, it looked just a tad worse. Going to medium will be a huge difference).
BF1 is fine, max texture consume <3gb.
Witcher 3 is extremely good optimized. Even in 1440p maxed out, it uses up less than 2,5 gb Vram.
Games that can get close to 6-8gb Vram usage in 1080p are:
- Deus Ex Mankind Divided
- Mirror's Edge Catalyst
- THe last 2-3 Call of Duty games (so horribly optimized, they can easy fill 8gb in 1080p. But according to tests, if you have 4gb Vram or less, you NEED to drop settings down to Low, since even Normal / medium will have some stutters here and there).
The biggest issue here isn't the VRAM it is the sneaky Nvidia trick that they also cut CUDA cores out on the "1060" 3GB version compared to the 6GB. So the 3GB isn't a true 1060 at all.
Right, aprox. 10% less Cuda Cores.
If Vram is not a limiting Factor, you will also have 10-11%~ less fps with it ^^"
If Vram DOES bottleneck in the games, the fps drop might jump from 10% up to 20-30%, or more.
So yea... Even if it's 50-80 bucks more.. really invest into 6gb. You will NOT regret it over the next 3 years~
Im no expert, but I would go for 6GB. Once you run out, it affects fps a lot and there is nothing you could do about it. But as mentioned above, some games are more VRAM hungry then others.
And also the CUDA core thing mentioned by others too. (I didn't know about that :P)
Everyone on here be showing off their rigs, so here I go:
Main Desktop CPU: Ryzen 1600 @ 3.65 GHz Memory: 2x8GB @ 3200 MHz Graphics: NVIDIA ASUS 1070 MOBO: ASRock Fatal1ty AB350 Gaming-ITX/ac Storage: NVME M.2 Crucial P1 SSD; SATA Crucial MX500 SSD; Seagate BarraCuda HDD.
Acer Aspire 5755G CPU: Intel i5-2410M @ 2.30GHz Memory: 6GB DDR3-1066 SDRAM Graphics: NVIDIA GT 540M 2GB Storage750GB 2.5" 5400RPM HDD Display15.6" 1366x768
18 minutes ago, jpfeif said:
Im looking into the GTX 1060 and I want to know how much Vram matters at 1080p med-high settings.
VRAM means absolutely nothing until your computer goes, "oh shit! I need more!"
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
14 minutes ago, Kd4lif3 said:
I have a 1070 and on max settings in gta online I never pass 4gb. Game nowadays will do just fine on the 1060. The only reason to get anything more is for high hz refreshing monitors, higher res, or future proofing
Well, GTA (Online) is not the best example for all Games out there... ^^"
Just because it never passes 4gb there, it doesn't mean, it won't pass 4gb in any other game.
Play Rise of the Tomb Raider maxed out in 1080p (for the lols, deactivate Anti Aliasing.. since SSAA is way too hardcore)
