There's no point in doing separate looks unless you're specifically doing it to add loop complication in order to fill a huge case and improve aesthetics.
https://linustechtips.com/topic/808073-reservoir-required/#findComment-10148474
8 hours ago, zMeul said:
absofuckinglutely
I just thought that cause AIOs don't so you don't need it...interesting
Just wanted to cut down cost
https://linustechtips.com/topic/808073-reservoir-required/#findComment-10148477
If they are two completely separate loops, then yes.  But if you pipe them in the same loop, then no.  You can do this by hooking up the output of the pump to the intake of rad 1, then the output of rad 1 goes to the input of rad 2.  The output of rad 2 goes to the input of the reservoir and you then complete the loop by connecting the output of the reservoir to the input of the pump.
Just remember, what goes out must go in.
Edited by kb5zue
https://linustechtips.com/topic/808073-reservoir-required/#findComment-10148484
Multiple loops add cost.
https://linustechtips.com/topic/808073-reservoir-required/#findComment-10148491
You don't need a res at all, just easier to bleed and safer to run. Ran my main rig without one for quite some time. I use a t fitting with a small piece of tubing which acts as a res.
https://linustechtips.com/topic/808073-reservoir-required/#findComment-10149300
@WhiteHoody
You can use two pumps with one reservoir but it would still be one loop and not two, so seeing as your sobriquet is WhiteHoody, you need to figure out if you want a dual loop with two reservoirs and two pumps or a single loop with one reservoir and two pumps.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/808073-reservoir-required/#findComment-10149803
