Apologies if this is in the wrong section, I thought my problem was most relevant to this section so here I am posting.
I'm looking to pick up a NZXT Hue+ (kit includes 4 RGB LED light strips) and a 3 pack 140mm NZXT Aer RGB fan plus an additional 140mm Aer RGB fan to get some RGB going + populate the three 140mm fan slots at the top of the case plus another 140mm fan slot at the rear of the case.
To my understanding, each 'channel' on the NZXT HUE+ can address up to 40 individual LEDs, or up to 5 Aer RGB fans (120 or 140mm).
My problem is: How do I actually connect the fans together? I assume I would need to daisy chain the fans together: i.e connect the right most fan (at the top of the case) with the middle one, then with the left one, then the rear one, then into the NZXT HUE+. Would I need to buy additional cables to make this happen? Do the fans/ NZXT HUE+ kit come with these cables?
I tried looking up unboxings and installation but they only ever show the NZXT Hue+ and some
RGB LED light strips, or they show the fans but never how they connect them together.
Sorry if this is a bit confusing, if I need to clarify anything please let me know. Thanks!
Edited by Special Agent 星雨
I'm no Special Agent myself, but my Dad was!
Ryzen 7 3700X
Lian Li Galahad 360mm White AIO
4 x 8GB G.Skill Trident Z RGB
Asus X570-E motherboard
KFA2 RTX 2080Ti SG
EVGA 850W P2 PSU
Samsung 970 Pro SSD, Crucial MX500 SSD, WD Blue HDD, WD Blue HDD, WD Green HDD, Silicon Power SSD.
All wrapped in a Lian Li PC-O11 Dynamic XL case.
https://linustechtips.com/topic/808072-nzxt-hue-installation/
