7 minutes ago, jonnyGURU said:
What's the brand on the front of the PC?  If it's just something a shop "pre-built", it's probably standard ATX stuff.
The pre-built stuff that doesn't tend to be standard are the big brands like Dell, HP, Lenovo.
So your the jonnyGuru? :D
https://linustechtips.com/topic/807705-help/#findComment-10146426
I can give you details about the psu brand once i reach home
https://linustechtips.com/topic/807705-help/#findComment-10147792
12 hours ago, TheWildGamer_ said:
Its Lenovo, but the psu brand is chinese
Lenonvo is Chinese. :D
And if you mean "the PSU is Chinese" as in "the label is written in Chinese", that's normal for China.  So if the brand name is in Chinese, the PSU might still have a model number that uses regular roman letter like "AT-500" or "GW-400" or something like that.
So, at this point, it's best to just measure the L x W x D of the PSU and see what you have there.  If it's 150mm x 140mm x 86mm, it's standard ATX.
https://linustechtips.com/topic/807705-help/#findComment-10149920
it says max output not exceed 170w
which i guess isnt enough for a gt 1030 and i5 3470s and 8 gbs of ram(check the main post)
https://linustechtips.com/topic/807705-help/#findComment-10159962
