Bitspower Z-Multi question
Solved by W-L,
1 hour ago, CaptainSav916 said:Does anyone know what metal they use for the pipe? I am doing a full copper/Nickel plated loop and I cant find out what material they use for the inlet pipe. I am looking at the full clear acrylic version for my loop in a Corsair 400c. If you guys know any decent reservoirs under 150mm that dont use aluminum that can be horizontally mounted please let me know!
It's a nickel plated brass tube, or acrylic tube usually. EKWB makes clear acrylic inlet tubes if you need.
