8 minutes ago, Ruwaaid said:
how much of a benefit can i get?
5 minutes ago, jonbush1234 said:
maybe 5x better performance of a m.2. the max speed overall of a m.2 is 32gbs vs of the 6gbs of the sata
It's negligible outside benchmarks - I actually think my XM941 is slower than the SSD I replaced with it
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/807481-final-build-plan-help/#findComment-10142579
I think the 1600 comes with a stock cooler as well. Since you plan on upgrading cooling (not using the included one), you may want to upgrade to the 1600x for $30 - moving from base of 3.2 to 3.6. Theoretically 13% better CPU performance for a total system cost increase of 2.3%.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/807481-final-build-plan-help/#findComment-10142587
you can OC a 1600 FYI
https://linustechtips.com/topic/807481-final-build-plan-help/#findComment-10142589
Yes, but a 1600's boost is said to hit 3.6... And the 1600x 4.0.
https://linustechtips.com/topic/807481-final-build-plan-help/#findComment-10142601
1 hour ago, nerdslayer1 said:
 you can OC a ryzen 1600 to 4ghz, 1600x is just a factory OC version.
Hmmm. Never knew that. Thanks.
https://linustechtips.com/topic/807481-final-build-plan-help/#findComment-10143006
