Title says it all. No matter how far I put the back strap back I always experience the front being heavy. If I make it tighter it's decent but then it squeezes and hurts my face. (I have glasses if that makes a difference)
I posted this yesterday but no one replied. I'm getting frustrated, i've spent at least an hour trying to figure out what the heck i'm doing wrong here.
https://linustechtips.com/topic/806571-vive-feels-front-heavy/
because it is ? maybe look into getting the deluxe headstrap? I've tried a friends vive but I personally have a rift. Maybe try and make a mod for it so it cradles the back of your head a bit more? I would also try reddit.com/r/vive instead probably a bit more helpful for this stuff. Could try and add weights to the back to try and counter it ? I didn't really have an issue with it but I only used it for about 15 minutes so I haven't had extended play time with it.
https://linustechtips.com/topic/806571-vive-feels-front-heavy/#findComment-10132776
Just now, JabroniBaloney said:
Try reducing gravity.
Can you stop being a smart ass? I'm trying to resolve a potentially simple issue and you're not helping by pointing out the obvious. This is an actual problem that very likely has a solution.
https://linustechtips.com/topic/806571-vive-feels-front-heavy/#findComment-10132858
Well, try to get some sort of soft hat you can wear under the vive. This will make it more cushioned so you can tighten it a bit more, and will increase the total area for the vive to strap to. The only downside is it will make your head warmer. If anything you can possibly try a headband?
https://linustechtips.com/topic/806571-vive-feels-front-heavy/#findComment-10132871
