need help - how do references work in c++?
Go to solution Solved by Sniperfox47,
42 minutes ago, Pachuca said:
~snip~
function1: They need to be referenced because you want to change the value of the passed parameters from within the function. A referenced parameter is passed as a reference of the original variable while a standard parameter is passed as a distinct copy of the variable, so the changes would be lost at the end of the function.
function3: The exact opposite of the argument above. You don't *want* to change any numbers inside the function so you pass copies. The value of the function is it's return which is getting assigned to a variable in your main. It's a double because it returns a double. The other functions are void because they return nothing.
funcOne: Because, in the last line of this function, you change the value of x, and you want that change passed up to the higher scope so you use a reference, but you don't want to change anything about y with this function so you pass it as a copy.
nextChar: Because it increments z and you want that change to be passed up.
P.S. something's screwy in the code... z isn't defined above where it's used in the main loop, amount in function 3 isn't defined and it always returns 0, and function 3 is written as a void function even though it should be a double function. Are these typos?
I'm trying to figure out how user declared functions operate with references. This is one of my homework's and I'm a bit confused. I have to make a series of functions that have to be called in main. for example this code is wrong and I need to understand why. I know how to write it the write way because someone showed it to me, but I can't figure out why this is wrong.
void function1(int x, int y, char a);
void function2(double num1, double num2);
void function3(double num1, double num2);
void function4(double num1, double num2, double num3);
void funcOne(int x, int y);
void nextChar(char z);
int main(){
int x, y;
char a;
double num1, num2, num3;
function1(x, y, a);
function2(num1, num2);
num3 = function3(num1, num2);
function4(num1, num2, num3);
    cout << "The value of x is currently: " << x << endl;
    funcOne(x, y);
    cout << "The value of x is now: " << x << endl;
    nextChar(z);
    cout << "The value of z is now: " << z << endl;
return 0;
void function1(int x, int y, char a){
x = 1;
y = 0;
a = 'a';
voind function2(double num1, double num2){
cout << "Please enter num1: ";
cin >> num1;
cout << "Please enter num2: ";
cin >> num2;
void function3(double num1, double num2){
double total = 0;
    if (num2 > 4) {
        amount += ((num1 - 4) * num2) * 2;
        amount += 4 * num2;
        return total;
    else {
        amount = num1 * num2;
        return total;
void function4(double num1, double num2, double num3) {
    cout << "For num2 " << num2 << "  and num1 " << num1 << " total ";
    cout << fixed << showpoint << setprecision(2);
    cout << num3 << endl;
void funcOne(int x, int y) {
    int tempNum;
    cout << "Please enter a number: ";
    cin >> tempNum;
    x = (x * 2) + y - tempNum;
void nextChar(char z) {
    z++;
I'm confused why somethings need to be referenced and others don't. the correct way to write the code would be to write the functions like this:
void function1(int& x, int& y, char& a); //why do these have to be referenced?
void function2(double& num1, double& num2);
double function3(double num1, double num2); //why does this not have to be referenced like the above two? Why does it have to be double and not void?
void funcOne(int& x, int y); //why is only x referenced here?
void nextChar(char& z); //why does this have to be referenced?
https://linustechtips.com/topic/806559-need-help-how-do-references-work-in-c/
~snip~
there are some mistakes, i tried to type it as best as I could. function 3 is double, I wasn't sure why until I saw the error message saying void can't convert to double.
