Dividing the load among connectors on PSU, or the same as if on less connectors?
The wires are arranged like this in Dark Power Pro 11 850w :
Cabling - BeQuiet! P11-850W | ||
Type of Cable | Length from PSU | +12V Rail |
20+4 pin ATX connector |
610mm | 12V1 |
Modular Cables | ||
5.25"+5.25"+5.25" | 600+150+150mm | 12V1 |
5.25"+5.25"+3.5" | 600+150+150mm | |
5.25" | 600mm | |
SATA+SATA+5.25"+5.25"+3.5" | 600+150+150+150+150mm | |
SATA+SATA+SATA | 600+150+150mm | |
4+4 pin CPU | 700mm | 12V2 |
8 pin CPU | 700mm | |
6 pin PCI-E | 600mm |
12V3/ 12V4 |
Dual 6+2 pin PCI-E |
600mm 600mm |
600mm 600mm |
600mm |
Auxiliary Cables | ||
OCK switch | 700mm | |
5.25" Fan + 3 Pin Fan | 600+150mm | |
Using one cpu 8 pin connector per strand of wires from the power supply would be better in your case.
More wires between power supply and motherboard is better (there's less energy lost in the wires, the wires heat less etc)
The 7900x and socket 2066 are in general very power hungry and the vrms also heat up a lot, you can read a lot about it here: http://www.tomshardware.com/reviews/-intel-skylake-x-overclocking-thermal-issues,5117-3.html
The cables used in SATA strips can generally handle about 10A on each voltage wire, so around 120 watts of power from 12v, around 50w on 5v , around 35w on 3.3v (almost never used in PCs) and each sata connector in theory can do 4.5A on each voltage so about 55w on 12v but generally you wouldn't want to go over 30 watts on each sata connector. Basically everything you mention barely uses 20 watts (less than half the maximum capability of each sata connector)
Also note that your fans will use 12v while SSDs will probably use 5v mostly ... so you don't add the power used by SSDs to the power used by fans, they're different voltage lines.
