I work in Multimedia Company, so I need to reduce my rendering time. I already have pretty nice monitor and Mini-ATX Case. I got 500 Buck of initial budget, I got an idea to use AMD Ryzen + 1050 Ti. or can you give me another alternative and/or recommendation ? Thank you.
https://linustechtips.com/topic/806365-pc-build-for-3d-rendering/
What resolution do you render at?
micro-atx or mini-itx? just to confirm.
1 minute ago, wowotek said:
i used to work at 720-1080p, but with this maybe I got 2K in Mind
Micro-ATX sorry.
So you need, CPU, motherboard, GPU and a case for $500?
mATX case? So you are are upgrading from a used PC or just bought the case?
Desktop benching:
Same I'm confused. :/
2 minutes ago, wowotek said:
hmm, I said it is initial budget, so maybe you got any recommendation for me maybe instead of full gear i can go CPU MOBO and PSU first or something else.
Still confused. Do you need a new PC?
Just now, wowotek said:
this is from my old pc, it's too old LGA775 mobo as far as i can remember. so maybe i can use this
Sorry for not reaching the point. I'm trying to ask whether you will need new storage drives.
Desktop benching:
wasn't able to fit a 1050ti into the budget:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ Amazon)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($65.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($53.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Best Buy) you should still be able to reuse the old hdd you have from your old pc, you can skip this for some extra ram if you reuse. make a 100-200gb boot partition and clone that to an ssd in a future upgrade.
Video Card: EVGA - GeForce GTX 1050 2GB SSC GAMING Video Card  ($94.99 @ Newegg)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $481.93
Generated by PCPartPicker 2017-07-12 08:43 EDT-0400
yea I need a brand new pc, and I consider using a new storage drives. and also 500 bucks is my initial budget, so i can upgrade the pc later.
Total: $481.93
so you give me full pc build, if i say i don't really need this fast, and i can upgrade this later. do you still give me the 1050? or 1050 is good enough for 3D rendering and make later budget for upgrade to SSD instead?
Ryzen doesn't have iGPU, so in order to use it a GPU is needed. In that case, going for something terrible like the GT 610, then upgrade in the future means wasting money (on that crap card).
Desktop benching:
yeah i know that i mean maybe i buy the processor and motherboard first and then buy the GPU later, considering 1050ti is better than 1050, i got GT210 from my old pc maybe i can use it while i wait ?
