https://au.pcpartpicker.com/user/Xynah/saved/#view=vyg23C
Looking for any tips/pointers on this build.
1600 is to over multitasking/streaming
1600 & Motherboard are on sale on Amazon
My SSD choice was between EVO and PRO series, and I came to the conclusion that the PRO series wasn't worth the price.
FireCuda is on sale on amazon, if it wasn't I would've gotten the BarraCuda
I really wanted an RX 580 but I know how expensive they currently are, I found one at what I thought was a really good price - especially considering its 8GB
This was the cheapest monitor that met my standards
https://linustechtips.com/topic/806283-gamingstreaming-build-advice/
Looks good, no issues.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($295.00 @ PCCaseGear)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($124.00 @ Umart)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($185.00 @ IJK)
Storage: Samsung - 250GB 2.5" Solid State Drive  ($99.00 @ Umart)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($94.00 @ Shopping Express)
Video Card: Sapphire - Radeon RX 580 8GB NITRO+ Video Card  ($479.00 @ PLE Computers)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case  ($69.00 @ Mwave Australia)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($95.00 @ Shopping Express)
Monitor: Asus - VG248QE 24.0" 1920x1080 144Hz Monitor  ($376.00 @ Umart)
Total: $1816.00
Generated by PCPartPicker 2017-07-12 17:00 AEST+1000
Storage: Crucial - MX300 525GB 2.5" Solid State Drive  ($215.00 @ IJK)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card  ($709.00 @ Scorptec)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($129.00 @ PCCaseGear)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($85.00 @ Shopping Express)
Total: $1836.00
Generated by PCPartPicker 2017-07-12 16:56 AEST+1000
He needs a monitor in that budget too.
2 minutes ago, Vespertine said:
RX 580 can't play 144Hz at triple-A titles unless you turn the settings pretty low.
Not really, it would be fine for most games at med-high.
PSU Tier List
My specs
PC:
Peripherals
Just now, Vespertine said:
Considering it is around 60-80fps in Ultra BF1, the medium would be more suited for around 120-144Hz than high.
Hence why I said Med-high, not just high (BF1 isnt the only game out there either).
PSU Tier List
My specs
PC:
Peripherals
I would consider a high wattage psu...
If you want to hit the sweet spot for the efficiency curve 50-75%....
Your parts list is around 90%.... 87% if you want to be closer I would think a 500W would be a better option
so maybe a larger PSU to save headaches and possible blue screens
8 minutes ago, StripperGrandpa said:
I would consider a high wattage psu...  80 PLUS at 100% load is going to be 360W from PSU your system requires a 390+....
That's not how a PSU works man. 80% means 80% efficient. A 500W 80% PSU delivers 500W to the PC but pulls around ~625W from the wall.
Edited my speech to text didn't understand me very well so i fixed what I meant.
Yeah that makes better sense :) But tbh modern PSUs can happily run anywhere within their range. 50% is around peak efficiency and like Jayztwocents says in a recent video he would use a 1000W PSU in a 500-600W system for best efficiency. However he also says the energy savings you make by using the more efficient PSU can easily be outweighed by what the overkill PSU cost you in the 1st place.
