Probably have bad airflow in the case.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/805746-1080ti-advice/#findComment-10124087
My first advice would have been to test it with sidepanels off and stuff. However, please tell me what is the ambient temperature in the room? If it's 40°c, don't expect it to run any cooler.
But if i'ts more human temperature, the only thing I recommend is bringig it back. If they ask why, tell them you see insane temperatures while gaming on FACTORY OVERCLOCK, and not custom, and you think there  might be an issue with the thermal paste. Do not attempt to remove/replace the thermal compound on your own, since it may void your warranty.
If you know a  bit about sillicone, try to convice them your card's power delivery or chip might be faulty, and this is why you get such high temperatures. This might get you a brand new card to enjoy.
Hope I helped.
https://linustechtips.com/topic/805746-1080ti-advice/#findComment-10124135
