Hi, I am about to buy a new PC and kinda dont know what parts are the best for their price etc. The PC will be primarily used for gaming (Overwatch, WoW, Diablo, hots, lol, would like to also try witcher) at 1080p and occasionally it will be used for 3d stuff in Cinema 4D. Because I have no clue if I should get amd or intel i made two builds which differs only in CPU, MB and RAM (I am planing on getting more ram later so only 8gb for now). My budget is 25 000 czech crowns, thats roughly 1090 usd but you dont have to go to the limit. Also this budget is for pc only, i already have the peripherals.
PCPartPicker part list: https://pcpartpicker.com/list/qXvNm8
Price breakdown by merchant: https://pcpartpicker.com/list/qXvNm8/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  ($86.98 @ Newegg)
Memory: Kingston - Savage 8GB (1 x 8GB) DDR4-3000 Memory
Storage: Corsair - Force LS 120GB 2.5" Solid State Drive  ($67.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.79 @ OutletPC)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card  ($143.61 @ Amazon)
Case: Corsair - 270R ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $636.34
Generated by PCPartPicker 2017-07-10 16:36 EDT-0400
PCPartPicker part list: https://pcpartpicker.com/list/dhyQbj
Price breakdown by merchant: https://pcpartpicker.com/list/dhyQbj/by_merchant/
CPU: Intel - Core i5-7600 3.5GHz Quad-Core Processor  ($209.99 @ SuperBiiz)
Motherboard: MSI - B250 PC MATE ATX LGA1151 Motherboard  ($88.89 @ OutletPC)
Memory: Kingston - FURY 8GB (1 x 8GB) DDR4-2400 Memory  ($71.16 @ Amazon)
Total: $719.41
Generated by PCPartPicker 2017-07-10 16:37 EDT-0400
https://linustechtips.com/topic/805555-first-pc-build/
2 minutes ago, Mister_Cro_Noob said:
Go with Ryzen. 3x more threads and larger l3 cache with favors multitasking. And intel has shitty box cooler.
nevermind, i though that you were recommending ryzen 3 xD
Edited by Blackhole890
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/805555-first-pc-build/#findComment-10121632
1 minute ago, faesh said:
Okay then =D, ryzen it is. Part-wise, are the parts I chose ok or should I change something?
Nope looks good, I'd get another 8gb stick in the future, and possibly upgrade the gpu (once prices come back down)
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/805555-first-pc-build/#findComment-10121709
1 hour ago, Mister_Cro_Noob said:
Try to fit Sandisk 240 GB SSD and try to change a motherboard to something from ASUS or Gigabyte or ASRock but rest is very good
What? Are you trying to say MSI's motherboards are inferior to these three? They actually have a better track record for reliability than most manufacturers.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/805555-first-pc-build/#findComment-10122052
Go with Ryzen. 3x more threads and larger l3 cache which favors multitasking. And intel has shitty box cooler.
The stock cooler is good enough for locked chips, but the Ryzen 5 chips are way better value.
As for unlocked Intel chips - the latest Kabylake 7600k and 7700k have a shit integrated thermal compound between the CPU die and IHS that makes them like 25 degrees hotter, so those aren't a great purchase either. This problem also affects the new 'Kaby Lake X' dummy chips.
https://linustechtips.com/topic/805555-first-pc-build/#findComment-10122062
Thanks for the info, now I know why Kaby Lake has so much thermal issues.
Kaby Lake X makes no sense as the whole line especially that i5 ffs. Only i9 and some i7s make sense in that line :/
https://linustechtips.com/topic/805555-first-pc-build/#findComment-10122079
Some MSI's boards are nice but I would personally recommend this one over MSI's B350 boards
https://linustechtips.com/topic/805555-first-pc-build/#findComment-10122083
On what basis? Also, that's over his budget.
https://linustechtips.com/topic/805555-first-pc-build/#findComment-10122085
Thanks a lot for the tips guys. I am gonna go with that MOBO I chose, cause its cheaper =D.
https://linustechtips.com/topic/805555-first-pc-build/#findComment-10125860
