Helloo, I've been researching and picking out parts for my first custom PC, he's what I've got https://pcpartpicker.com/list/NVGdQV . I based the build on the i5-6500, and the GTX 1050 Ti with a budget of 750$ - 850$. I've been swapping parts such as the storage and PSU for more cheaper/valued alternatives, I think I'm in a decent spot. What do you guys think of the parts/build? Are the parts compatible with each other? Is there any better parts I should swap out? Should I ditch the optical drive since I'm only going to use it once for installing drivers and windows?
I've also checked the sizes of the hardwares if they'll fit inside the case (PSU, CPU cooler etc), it'll be great if you guys can verify it, thanks in advance :D
https://linustechtips.com/topic/805473-first-entry-custom-gaming-pc-build-help/
This will be better...
https://pcpartpicker.com/list/qy76zM
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
This one?
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($65.98 @ Newegg)
Memory: GeIL - EVO POTENZA 16GB (2 x 8GB) DDR4-3000 Memory  ($104.99 @ Newegg)
Storage: SanDisk - SSD PLUS 120GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.79 @ OutletPC)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card  ($138.99 @ SuperBiiz)
Case: DIYPC - MA01-R MicroATX Mini Tower Case  ($25.97 @ Newegg)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($56.99 @ SuperBiiz)
Total: $700.69
Generated by PCPartPicker 2017-07-10 13:54 EDT-0400
16GB RAM, super powerful CPU, etc.
keep in mind that if you wait until the mining bubble pops, you will be able to put in an RX 470/570 instead of the 1050Ti, which would crush it in games. if I were you, I would wait until AMD cards return to their MSRPs
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
52 minutes ago, Alaradia said:
looks fine but do you really need a dvd drive?????
So, I'm guessing using a thumb drive is more convenient?  A friend of mine says using USB is more complex, I have little knowledge of this area hahaha. Ditching the dvd drive sounds great saves me 20$ to get a keyboard since I don't have one
I'm not really well informed of the cryptocurrency scene, how does this affect the prices of the GPU? It's strange lol
right now, miners are buying every RX 470, 480, 580, 570, GTX 1060, 1070, and even 1080 they can find, since it's profitable to use them for mining.
this has led to GPU prices being way overinflated. cards like the RX 470, which are 75% or so more powerful than the 1050Ti, used to sell for $140ish, sometimes dropping as low as $120 with rebates. this is obviously a way better choice for your PC, but since there's a shortage right now, it costs about $400 instead. when the shortage goes away, prices will drop back down.
Laptop:
Oooh I see now, on the bright side, we have this sale event that happens every late October, hopefully the GPU prices come down before that. Thanks for the help :D
