Hello guys!! The thing is I recently ended my new pc build and I livestream tournamentswith a friend (league tournaments mostly). Since I built this pc mostly for streaming (720p 60fps or higher) I wanted to know the best advanced settings to stream at 1080p 60fps (already streaming with that quality with no problems whatsoever, cpu usage stays around 26-28% maybe less  while playing/streaming at the same time) since I use the simple settings on obs studio. My pc build is.
-Ryzen 5 1600 (since I have not had any problems at all nor felt I lack cpu "power" I haven't oced it)
-evga 6gb 1060 ftw+
-16gb RAM (ruuning at 2133mhz. I'm a bit too lazy to flash the bios to oc the speed up to 3000mhz)
-Internet upload speed 10Mbps ( currently using 5Mbps for 1080p 60fps)
So uhm.. what would yo recomend, stay with simple settings or use the advanced ones, if so how should I set them up?? Leaving an image here of how obs advanced settings look like. Ty
https://linustechtips.com/topic/805248-need-some-help-with-streaming-settings/
kick encoding up to fast, should make a pretty nice difference in quality, but at fast you do start to see a pretty big rise in cpu usage.
as for bitrate, twitch currently recommends between 3000-5000 kbps its a balance between what your side can handle and what the manjority of viewers can handle, along with the quality of what you're sending out.
Also, If you want to really kick up the quality, use the Nvidia encoder,NVENC H.264 . It is far less taxing on your system than the cpu x264 encoder, and produces a better image than it. As for advanced settings, I can't help you there, because I use an AMD RX 480 8gb.
