So, I'm doing a full custom loop with rigid tubing for the first time, and I'm a little nervous. I'm also still not sure which graphics card I'll be including (thanks to the cryptocurrency mining fucking with prices), but it will be included in the loop. Right now it is just in planning stages. I'll be using the Fractal Design Define S(With the window) that will be painted white to better go along with the white and black color scheme. Otherwise, these are the parts I've picked out so far:
Radiator: Hardware Labs Black Ice Nemesis GTR Satin White 360 http://www.performance-pcs.com/hardware-labs-black-icer-nemesisr-gtr-satin-white-radiator-360mm.html
Reservoir: EK-RES X4 250 (R2.0) https://www.ekwb.com/shop/ek-res-x4-250-r2
Pump: EK-XTOP Revo D5 PWM - Plexi (incl. sleeved pump) https://www.ekwb.com/shop/ek-xtop-revo-d5-pwm-plexi-incl-sleeved-pump
Fluid: PrimoChill True Opaque Sky White https://www.primochill.com/collections/true-opaque/products/primochill-true-infused-insanely-concentrated-liquid-pre-mix-8oz-opaque-sky-white-sx
CPU waterblock: Phanteks Glacier C350A http://www.phanteks.com/PH-C350a.html
Tubing: Bitspower None Chamfer PETG Link Tube https://bitspower.com/html/product/pro_show.php?products_id=4106
Fittings: Bitspower G1/4" Carbon Black Enhance Multi-Link For OD 16MM https://www.bitspower.com/html/product/pro_show.php?products_id=3708
Fans: Noiseblocker NB-ELoops from BlackNoise
I will be using some of Bitspower's other Carbon Black fittings for the bends, but I still want to figure out what I'm going to do with that. I'd really appreciate some input on my selections, and if you genuinely think some modifications are in order.
Otherwise, here is my list of components: https://pcpartpicker.com/list/rMGktJ
https://linustechtips.com/topic/804746-thoughts-and-opinions-please/
Perhaps you want to consider a drain system and a temperature probe for the water.
7 hours ago, BluJay614 said:
Looks like a solid system and loop! I can't think of anything to add besides what For Science! said.
I see you are considering purchasing some of your components through PPCs, so I just wanted to let you know that I am happy to help your purchase in any way that I can. Feel free to contact me directly at matt@performance-pcs.com.
Thank you for your business!
