Connection speed requirements for Streaming
Solved by Skiiwee29,
24 minutes ago, indexikki said:My current build is Ryzen 7 1700/16gb DDR4 3200
Don’t have a VGA yet because of obvious reasons so while I’m waiting for Vega I have to stream on GTX 460
So, assuming I’m planning to stream games that DO NOT HAVE significant GPU requirements, in fact these games have very low requirements. can play on my GTX 460 super fast.
Now, I’m clueless about streaming and what I need to know is if my VGA will affect the stream quality, in a bad way ofc.
While PLAYING these games is not an issue for GTX460, I have no idea if 460 can handle streaming
The only way the GPU would affect streaming is if you used it to stream with, which you wont with the 1700. Use your CPU and it will have zero impact on the stream.
