So,i know laptops CANNOT(in genral) be upgraded beyond storage and RAM.Altough there is a way to ''tweak'' some elements. As such i wanted to share a little trick you can do to ''upgrade'' your sound card,or at least,make it better somehow. Also ,it can sometimes work on your Desktop if the card will allow it.
So at first : go to the sound panel on the bottom right corner of your UI. right-click on it and select read peripherals,after that,select your main sound peripheral and right click on it too.go to properties,advanced statistics,and there you should see a panel that reads : some amount of bits, 48000 hertz . you want to set that to 192000 hertz (studio quality) and the maximum amount of bits you see. And there!!! you just somehow got your sound better by letting a better range of frequencies take a shot at your sound!!! Now you can also enable sound equalization in whatever sound software is used for your sound card and now the sound will ''sound'' a little bit better,louder than shitty whispering,and there you go!!!
Now enjoy studio quality sound and loudness and now you can fap to HD tracks of your porn (wait ,what???....)
LAPTOP : G701VI XS72K   CPU: Intel Core I7 7820 HK @ 4.2 GHZ  | GPU : Nvidia GeForce GTX 1080 | RAM : 32GB APACER Technology 2400mhz |
Monitor : Integrated G-Sync 1920 X 1080 120HZ Screen | Storage : 2x 128GB NVME SSD | USB 3.0 type A x 3 ; 3.1 x1 type C ; 3.1 10GB/S type C x1| Displayport 1.4 x 1 | HDMI 2.0 x1
COOLING : Vapor chamber supplemented by Dual Fans
https://linustechtips.com/topic/804141-tweak-laptop-audio-card/
