Gaming and light use of Da Vinci Resolve, Avid Media Composer, Nuke, and After Effects for the next year. Then the year after heavy use for the above programs and light gaming (On my placement year!)
I have a 1440p monitor, so I'm guessing the 1080 will kill that at at least 60fps High? (Only recently has PC become my main gaming machine, so i'll be getting some future AAA games like Destiny 2, ATM I mostly play Minecraft!, my most intensive game is Ashes of the Singularity and probably Metro Last Light, neither of which I've played yet)
Here is the PC Part Picker link, and an Imgur Album with my current basket!
So I'm going for a black and purple build, Mostly everythin black then purple lighting. I wanted to get the cable extensions as purple, but I thought it'd look silly with them just as purple with no other no light purple source.
I'm also tempted to get the be quiet dark rock pro 3, as it'll save me getting the extra Noctua fan to replace the tan ones on the NH-D15.
I've gone with 2 Silent Wings to put in the front of the case, and I'll move the included 12 front one to the back.
The saved for later LED strip is just incase the include Phantex one doesn't give me the shade of purple I'd like.
Edit, I want to add that I already have all the storage from my previous comp! A couple SSDs and a couple HDDs
https://linustechtips.com/topic/804060-ryzen-5-first-build-help/
This would be a much better build for your uses:
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  (£282.00 @ Aria PC)
CPU Cooler: Noctua - NH-D15 SE-AM4 140.2 CFM CPU Cooler  (£74.99 @ Amazon UK)
Motherboard: Asus - STRIX B350-F GAMING ATX AM4 Motherboard  (£111.26 @ BT Shop)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3000 Memory  (£134.99 @ Amazon UK)
Storage: Seagate - BarraCuda Pro 5TB 3.5" 7200RPM Internal Hard Drive  (£132.60 @ Alza)
Video Card: Palit - GeForce GTX 1070 8GB JetStream Video Card  (£355.77 @ Amazon UK)
Case: Phanteks - Enthoo Pro ATX Full Tower Case  (£91.55 @ Amazon UK)
Power Supply: Corsair - RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£85.47 @ Amazon UK)
Total: £1268.63
Generated by PCPartPicker 2017-07-07 18:08 BST+0100
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
Nice looking build! But make sure and get an SSD for a boot drive.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
That build will monster anything up to light 4K. You will see gains with a modest OC on the CPU and that motherboard despite being a B platform is able to do OC'ing but note that they don't have the option for voltage offset. For 1440p at 60 you should have no problems. I would recommend as anyone would likely do get a good SSD for your OS and critical games/data. \
don't follow the suggestion of getting a worse gpu to get a better cpu, but either get a 1600 or a 1700, they're identical to their x counterparts, the x ones just have a factory OC, and overclocking isn't all that difficult unless you're looking to squeeze out every bit of performance possible
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Total: £1268.63
The palit doesn't have RGB options, and the 1070 strix which does is only £90 cheaper for a 27% increase in performance and a longer life span on games in the future.
What does that voltage offset mean for OC'ing?
I feel like I'm playing the lottery though with getting a 1600 that will overclock to what is almost guarented with the X version. I might be ill informed though...
you'd have to get the worst lottery loser to not be able to at least meet the 1600x from a 1600, you should be able to get at least 3.8 on either one though
desktop
HTPC
Thing is I'd like to hit 4ghz at minimum hit 3.9 on an oc!
Then a 1700x would be in order, and possibly a better motherboard (like a cheaper x370 board). Something like the asus prime may do nicely.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
Unfortunately the 1700x is just out of my price range. I can however get the 1700, and OC that
I was only suggesting the 1700x if you REALLY wanted to guarantee that 3.9-4.0ghz, the top 72% of 1700's will reach 3.9 but you may lose the lottery.
8086k Winner BABY!!
Main rig
GFs System
If you're going to OC the CPU using a Voltage Off-set lets the Motherboard dial back the clock and voltage as normal when the system is at idle/light load. If you don't have a Voltage Off-Set option you're locking the Voltage of the CPU at what ever you set it 100% of the time. In other words if you OC without it, you will shorten the life of the CPU. If you cool it well enough it may not matter, but it's something you should take into account.
Dang it... The B350 Strix was perfect as well... So this means I should either fork out the extra 60 quid for the x version, or try and find an rgb mobo that's somewhat black on the X270(???) platform
Edit: Just looked at the base difference between the 1700 and X, 6% increase doesn't seem worth. New Mobo I guess...
If you're not going to push a overclock past 100Mhz or so then you shouldn't even need to up the voltage. And again if you cool the CPU well enough it's not that big of a deal. It's just good to know the value of an Off-Set. I haven't used the B350-Strix only the B350 Prime so I don't know for sure if it has better support of Overclocking.
Thank you! I think i'll be going with the 1700 and the same Mobo
the x chips don't give higher max OCs despite AMDs suggestion that they would, at least everything I've seen shows no difference in max OCs obtainable. but good choice on the 1700
desktop
HTPC
