Overclock CPU with a OEM Mobo
Go to solution Solved by Aelita Sophie,
14 minutes ago, GanstaKingofSA said:
Hi,
I have a Athlon 64 X2 5000+ and it has run alot of games very well such as H1Z1 King of The Kill. I want to increase the Core Speed of this CPU without touching Voltage as I dont want a toasted PC. Unfortunately I have Installed it on a OEM Motherboard, a eMachines WMCP61M and has very little info in the BIOS for me to OC it. Am I stuck with a No OC or I can with software or flashing a BIOS Mod?
I highly recommend not trying it at all. OEM motherboards lack features to get a safe overclock to begin with. Nor will they ever support it unless they specifically specify it.
You could flash the BIOS with a modded version, if there exists one though. But this isn't without huge risks. If not done properly or a power outage happens, or the rom is corrupted or what ever, it will brick your motherboard with no way to get it to work again. Most OEM motherboards do not have a dual-bios option in case something goes wrong. Especially the one you have due its age.
Software overclocking is not recommended, and will probably not work at all, though you can try this safely. It either works, or it doesn't. If it works and you go to far, it will simply crash the PC and make it reboot with the original settings. Just don't crank it to high. But the again, nor your CPU or Motherboard has been made with even the slightest overclock in mind. So I highly dis encourage it.
Hi,
https://linustechtips.com/topic/803976-overclock-cpu-with-a-oem-mobo/
Hi,
Main RIG: i7 4770k ~ 4.8Ghz | Intel HD Onboard (enough for my LoL gaming) | Samsung 960 Pro 256GB NVMe | 32GB (4x 8GB) Kingston Savage 2133Mhz DDR3 | MSI Z97 Gaming 7 | ThermalTake FrioOCK | MS-Tech (puke) 700W | Windows 10 64Bit
Mining RIG: AMD A6-9500 | ASRock AB350 Pro | 4GB DDR4 | 500GB 2.5 Inch HDD | 2x MSI AERO GTX 1060 6GB (Core/Memory/TDP/Avg Temp +160/+800/120%/45c) | 1x Asus Strix GTX 970 (+195/+400/125%/55c) | 1x KFA2 GTX 960 (+220/+500/120%/70c) | Corsair GS800 800W | HP HSTNS-PD05 1000W | (Modded) Inter-Tech IPC 4U-4129-N Rackmount Case
Guest RIG: FX6300 | AMD HD7870 | Kingston HyperX 128GB SSD | 16GB (2x 8GB) G.Skill Ripjaws 1600Mhz DDR3 | Some ASRock 970 Mobo | Stock Heatsink | some left over PSU  | Windows 10 64Bit
VM Server: HP Proliant DL160 G6 | 2x Intel Xeon E5620 @ 2.4Ghz 4c/8t (8c/16t total) | 16GB (8x 2GB) HP 1066Mhz ECC DDR3 | 2x Western Digital Black 250GB HDD | VMWare ESXI
Storage Node: 2x Intel Xeon E5520 @ 2.27Ghz 4c/8t (8c/16t total) | Intel ServerBoard S5500HCV | 36GB (9x 4GB) 1333Mhz ECC DDR3 | 3x Seagate 2TB 7200RPM | 4x Western Digital Caviar Green 2TB
