Okay, I need help choosing components for a new pc because I'm currently using a laptop to build my youtube channel and it's been presenting problems left and right.
my laptop is an ASUS gaming notebook
GeForce GTX 960M 2 GB GDDR5
  • Intel Core i7 6th Gen 6700HQ (2.60 GHz)
  • 16 GB Memory 1 TB HDD
  • 17.3" Full HD 1920 x 1080
  • 16.30" x 10.60" x 1.20"-1.30" 6.60 lbs.
  • DVD±R/RW
  • 1 x Mini DisplayPort 1 x HDMI
  • 1 x USB 3.1 Typ-C (Gen 1)
  • 1 x USB 3.0
  • 2 x USB 2.0
It's a relatively good laptop but compared to the rigs I've seen it fails in comparison, even most subpar pc builds I've seen work better which I hate because I spent $2000 on the laptop.
so im having trouble looking for what I want for my new pc, specifically with choosing between AMD and Intel and other such products. I'm new to PC's so I don't know the differences, my current budget is $1,200 CAD. any advice or ideas would be great appreciated.
(Before people ask, my name "tree killer" is a term from my friend due to my career as a utility arborist and forest firefighter).
https://linustechtips.com/topic/803967-need-help-planning-a-build/
need os/monitor/peripherals?
We won't ask much about names and how long can you wait to build a PC?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
no I do not, I pre purchased all of those a few weeks ago.
LG 25UM58-P 25" 21:9 UltraWide IPS Monitor with Screen Split, Black
I have windows 10 pro 64-bit ready to be installed when I get the pc built and have already bought a keyboard and mouse and speakers.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($294.50 @ Vuugo)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($95.00 @ Vuugo)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Newegg Canada)
Storage: Crucial - MX300 275GB M.2-2280 Solid State Drive  ($119.99 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.95 @ Vuugo)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card  ($369.99 @ Memory Express)
Case: Apevia - X-QTIS-BK MicroATX Mid Tower Case  ($39.99 @ Newegg Canada)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($54.98 @ DirectCanada) change this to another 500-550w unit if you choose to get a used 390.
Total: $1184.39
Generated by PCPartPicker 2017-07-07 09:33 EDT-0400
Noice! And make sure to tag or quote people so they can see your reply: @herman mcpootis
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Total: $1184.39
Great build, though I'd get a 1050 Ti since 1060s are inflated now, spend the extra on a bigger SSD or R7 1700 (it'll help more with editing), and then save for a 1080 or 1080 Ti down the line
Mouse: EVGA X17
If you don't mind waiting, you could also wait for that paycheck and up the GPU to a 1070/1080.
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($381.87 @ Amazon Canada)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($129.99 @ Newegg Canada)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($112.99 @ Amazon Canada)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($62.50 @ Vuugo)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB SC GAMING ACX 2.0 Video Card  ($187.99 @ Amazon Canada)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case  ($69.99 @ Newegg Canada)
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon Canada)
Total: $1195.31 CAD
Generated by PCPartPicker 2017-07-07 09:46 EDT-0400
14 minutes ago, treekiller said:
@herman mcpootis how well would that build handle streaming through twitch/youtube while running high/very high graphics?
it should stream just fine, i'd recommend finding a used gtx 970/r9 390 and using the money to go get a 1700 as GPU prices are crazy high now.
5 minutes ago, treekiller said:
@herman mcpootis @LeinadTM I'll look into both builds, I'm going to look into the difference between AMD and intel because I have yet to learn the difference. Thanks for the suggestions.
AMD's Ryzen lineup seems to be aimed more at workstations, giving much higher core counts than Intel's flagship CPUs, and for a cheaper price. For example, the R7 1700 is almost $100 cheaper than the i7-7700K, and has twice the cores and threads. Basically, Intel CPUs are slightly better for gaming due to having naturally higher frequencies, but AMD CPUs are a lot better for value. Plus, slapping a good cooler on a Ryzen CPU will allow you to overclock to the point where it's better than a stock Intel CPU.
ryzen has lower average framerates than the current lga 1151 cpus, but higher minimum framerates which makes the game feel smoother and much better multitasking ability with the extra cores.
The 1060 Herman chose is priced ok, it translates to around $285 USD which is reasonable.
Total: $1195.31 CAD
Considering the price range op is looking at it's probably better to get a 1600 and use that money on a better GPU. Also SSD plus isn't great.
4 minutes ago, LeinadTM said:
AMD's Ryzen lineup seems to be aimed more at workstations, giving much higher core counts than Intel's flagship CPUs, and for a cheaper price. For example, the R7 1700 is almost $100 cheaper than the i7-7700K, and has twice the cores and threads. Basically, Intel CPUs are slightly better for gaming, but AMD CPUs are a lot better for value.
Ehhhh I wouldn't say SLIGHTLY, for 7700k vs r7 you're looking at 10-15% or so. That's the difference for 570 vs 580 and people don't say the 580 is slightly better.
Also $100 less for 1700 isn't accurate, even in Canada the difference is $60 or so and here in the us at the moment they're pretty much the same.
Also, I hate it when people say amd cpus are better value. Value is heavily dependent on scenario. If you look at someone who's only gaming, then the 7700k is better value than the 1700.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Another R7 1700 build - more storage, mATX case, slightly faster memory.
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($379.82 @ Amazon Canada)
Motherboard: Asus - PRIME B350M-A Micro ATX AM4 Motherboard  ($111.95 @ Vuugo)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  ($179.99 @ Amazon Canada)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($128.99 @ PC Canada)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($89.05 @ Vuugo)
Case: Cooler Master - N200 MicroATX Mini Tower Case  ($54.75 @ Vuugo)
Power Supply: SeaSonic - S12II 430W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Newegg Canada)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  (Purchased For $0.00)
Monitor: LG - 25UM58-P 25.0" 2560x1080 75Hz Monitor  (Purchased For $0.00)
Total: $1192.53
Generated by PCPartPicker 2017-07-07 10:13 EDT-0400
3 hours ago, treekiller said:
I've decided to wait about a month and a half, I found out through my boss that I'm getting a bonus and a raise at work so by the end of august my new budget should be around $4500.
Sweet.
1 minute ago, treekiller said:
@brob needless to say I'm not going to spend $4,500 on a pc, that's pretty overkill. probably going to be between $2,000 and $2,500
That will let you go with more ssd storage and a more powerful gpu.
