this one has me stumped, maybe you guys might have some ideas.
Computer will work fine, until i open up world of warcraft, yes i know, i still play that game. Here is where the problems start. the game runs fine as long as i dont touch the keyboard, i can run around with mouse, do anything i want to with the mouse, but as soon as i hit any key on the keyboard, the game freezes and stops responding. I have to force close the game. NOW, once that has happened, i go to chrome, same thing,, i can use mouse, but as soon as i use keyboard, freezes and stops responding. I can open up firefox or palemoon and everything works great. Also, when i hit windows key and try to type anything, it does not take any of the keyboard input. I can reboot and chrome works again, and windows key works again. everything is fine untill i try to run WOW again.
now sometimes i can leave the PC alone and come back later in the day and everything works fine, game will play as normal , no issues. but that is rare that it starts acting normal. I did uninstall the game and reinstall the game and it worked perfectly fine, next morning, fired up the game, same issues.
  I have tried different keyboards, i have tried several different usb ports, both rear and front. I have tried to update USB drivers, but windows says i have latest installed and there are none for win 10 on manufacture website. BIOS is up to date.
anything you can think of short of a reinstall of windows?
https://linustechtips.com/topic/803939-very-odd-computer-computer-problem/
Specs?
Keyboard model?
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
I'm just taking a guess here but maybe you've got a broken keylogger installed on your system that looks specifically for wow to fire up. Can you install windows on another hdd and see if the issue persists?
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
