I made a PC build based off the SkyTech Archangel GTx 1050 edition and it is $150 dollars cheaper and the only difference is case, I just wanted some advice on whether i should change something to something else, but i dont want to pay more (Budget of $520) If you find something that is better please feel free to tell me. https://pcpartpicker.com/list/M97r8K . There is the link.
https://linustechtips.com/topic/803681-i-need-some-advice/
Save a bit more money and get a skylake/kaby lake i3 6100/7100, it will perform about on par with the 6300, but will give you much more room for an upgrade when the time comes, the 6300 is way too outdated for modern gaming. My old rig had an 8350 and even that overclocked to 4.4 GHZ wasn't performing well. FX CPU's aren't for gaming anymore, but can be used for other lighter tasks.
This used to be a signature with a bunch of specs, but they're outaded.
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102385
2 minutes ago, TheArsenalGamer said:
Well this isn't going to be a permanent build, just temporary for now because it is better than my SFF PC.
If it's not permanent, I assume you plan to upgrade it in the future, issue is that with the FX line up, you have nothing to upgrade to.
Maybe just wait until Ryzen 3 comes out, what you want might be in that lineup.
What CPU is in your SFF PC? you might be able to just upgrade to a SFF 1050 if you want.
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102408
Just now, Tokeegee said:
If it's not permanent, I assume you plan to upgrade it in the future, issue it that with the FX line up, you have nothing to upgrade to.
Its a Intel Celeron 1007U which is sautered in by ASUS
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102412
Switch to G4560 based thing, get a better psu, other than that looks good.
4 minutes ago, Tokeegee said:
https://pcpartpicker.com/list/Bwr7jc Total is 537$, which I know is over budget, but you have more upgrade headroom, and you don't need that many fans.
Why 6100 when G4560? And why DDR3? Psu also isn't good.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102420
Yeah the pentium could do well too. I didn't see the DDR3, and the 500b is fine, it's been in my friend's PC for a while.
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102425
1 minute ago, Vespertine said:
Ignore the old message, I didn't click on the PCpartpicker link
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102449
Oh yeah, okay 330$
NVM, 350$, his budget was 520$. The RAM was added as only 4GB is in that system.
Yeah, great idea with the pre-built HP, I did the same thing with a friend, and he got a nice 3470/1060 system, this guy could probably do the same thing.
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102471
That doesn't mean it's a great choice tho. For the price you can get much better PSUs.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102476
5 minutes ago, Tokeegee said:
https://pcpartpicker.com/list/cxYrgL
Pentium added, and upgraded to DDR4
I hope you have a copy of Windows BTW
Why aftermarket cooler tho? Money would be better spent on an ssd
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102479
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($74.89 @ B&H)
Motherboard: ASRock - B250M Pro4 Micro ATX LGA1151 Motherboard  ($60.98 @ Newegg)
Memory: G.Skill - Ripjaws 4 series 8GB (2 x 4GB) DDR4-2400 Memory  ($59.92 @ Amazon)
Storage: PNY - CS1311 120GB 2.5" Solid State Drive  ($52.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card  ($144.99 @ SuperBiiz)
Case: BitFenix - Comrade ATX Mid Tower Case  ($30.02 @ NCIX US)
Power Supply: SeaSonic - S12II 430W 80+ Bronze Certified ATX Power Supply  ($31.98 @ Newegg)
Total: $504.21
Generated by PCPartPicker 2017-07-06 16:54 EDT-0400
EDIT: forgot to mention for Windows you can get it from kinguin or run windows without a product key (you just can't change background and a few other things)
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/803681-i-need-some-advice/#findComment-10102487
