How to overclock G.Skill DDR3 Ripjaws 1600MHz to 2133 MHz on A88XM-A/USB3.1?
I have a G.Skill (F3-12800CL 10S-8GB-XL) single stick running on above mentioned board (which is capable of upto 2400 MHz). As some of you guys, who read my previous posts, might know I have an A10 7890k with some serious Overclock issues because of my crappy ver. 0309 BIOS! idk much about O.c.'ing but I've contacted G.Skill Support as well on Tomshardware. They suggested me to try first C10 1600 MHz (default rating) and then go for C10/11 1866 and hence 2133 if all worked correctly. I have no options to change the XMP/DOCP profiles for ram in BIOS. It only shows SPD Info. What should I do now to crank it up to 2133?
System powered by Deepcool DE580 580 Watts PSU.595a15774857d_CloudS9_20170703_150836.thumb.jpg.178bb9aba5a9152de1e35a594d46641e.jpg
